Hi guys
this is my update.
the first ST-Link was broken
. When you plug in USB there should be a blue LED. :ror:
the second one have this. I connect +3,3V and - from ST-Link to ESC + and - .
then connect swclk to clk on ESC,
then swdio to data on ESC.
Open CubeProg plug in USB and refresh ST-Link and voilà i can connect. "thumbsup"
I did the optionbyte and a full chip erase, all seems good.
But i can not flash firmware
i tried many things most i can flash 10-30% then the connection lost.
After few hours i tried with +5v i can not connect...
So i plugged the USB start CubeProg connect with +3,3V OK, disconnect and switch wire to +5v(with connected USB) voilà i can connect.
Try to flash bootloader PB4v8 - OK
Try to flash Iflight 1.65.bin - OK
Try to flash Eeprom v1_7c00.bin from AlkaMotor - OK
Connect ESC to HGLRC F4 flightcontroller Dshot300, open ConfigTool 1.67 change Parameter according to Voodoobrew Video, save, finish.
Today i got my new Motor and will try out if it is running.
cu
BTW:
Is firmware iflight 1.65 special for crawler? If not did anybody know if there comes a special firmware for crawler?
