Redcat Picture Archive - No talking
here is my rig havent done much just changed the servos from those crappy plastic ones i broke first day and a better battery goin to do alot more soon!!
My first crawler
Rs10
Intergy roll cage
rc4wd 45t motors
Dx3e controller
Novak m2 dig
Hot bodies whites
double deuce nova foams
Steel gears and 10 tooth pinion front and rear
110mm adjustable shocks
Delrin links and skid plate
5500 mah 7.4 lipo
rear steer lock out
aluminum knuckles
Uploaded with ImageShack.us
RC4WD 55t motors
bent lower links flipped upside down to clear motors
3000mah stick pack
removed wings
HB rover white dots
locked out rear steering after servo went out
My RS10 so far...
!3kg servos front and rear
4 link f & r with custom top mounts
bent stock lower links
behind axle front steering
hpi savage springs
bent steering arms for clearance
aluminium rims and white rovers on there way.
My RS10. Rover white dots, with stock crawler. I changed the top mounting position of my shocks, and slid the lower shock closer to the axle, and put a pen casing over the front steering link. Also using a stick pack as my stock battery burnt up ;-) oh well.
The Belgian guy^^
So here it is...
Mods:
-Trimmed body
-Nosram home made cubic 7,2V NiMh, 4200mAh battery
-New motors: GWS - DC Motor EM400
-New metal geared servos: 2 times Power HD 1501MG 17kg
-CC Bec installed
-Metal transmition
-Wing supressor (the "Y" link invertion does not work:roll:)
-Stock tires and foam sipped and cut with 3.17 onces in each front wheels and 1.06 onces in each back wheels
Not mounted:
Losi comp crawler tires and rims with the same weight (had to mod the hole on the losi 12mm hex...:|)
My RS10
Rover tires, 8T Pinion and Body Crowd Pleazer.
Already buy just waiting shipman; Axial links, 15 kg Servos and Gmade R1 Tube Chassis Set
