Redcat Picture Archive - No talking
Couldn't stand the hummer body, so I fitted a New Bright 2004 Silverado body the day I got it. Next day rigged up head and tail lights, about $6 worth of LEDs and battery connector. Bent the stock links, Tower mg995 servos, Plastic skid I rigged up on the porch, Rover white dots with about 10oz's weight on the front and none on the rear. Moved the lower links to the inside of the chassis since they were constantly hanging up and covered them with poly tubing. Semi-Drooped the stock shocks. Added a 9.6v 3300mah battery, gave it tons more power, and put the 8t pinion on the rear to fix stall. My First crawler and I'm lovin it!!"thumbsup"
Next up, custom narrowed chassis with a milled skid, maybe 540s
heres some updated pics...
645mg hitech servos
HB Rovers blue dot
73 bronco body
proline roof rack
proline light bar
blue alluminum shocks not sure the make?
green springs
4 aluminum knucles
3300 mah stick
still more to come receiver/radio and maybe speed control HH454 pullers why not
Brushless RS10.
Novak Mongoose.
Bent Links.
HB Rovers.
Steel Gears.
Losi Shocks.
GetAttachment.aspx
Stock just cut off back of body... got big bore 115mm shocks on it now and hb rovers... ill upload more pics when i get my new servos this week also got bent lowers comin.... new to this but lovin every min of it.... oh its also got some great rim protectors haha
Tracy's RS10
ok so here is mine. not much to brag about. wing mod. mounted some longer shocks to the axles. lowered body 1 inch. cut foam in tires and drilled two holes in rims. removed half the side tread (mistake) of stock tires to help with grip. tires are much more softer but still are terrible.
Needs....better tires, better electronics, 540 mod servo. lock rear steer.
wants.....new chassis and body, bent 4 links, lipos batteries.
ars10aedit.jpg articulation courtesy of skoal cans.
ars10bedit.jpg axles mounted to shocks
ars10dedit.jpg wing mod
ars10edit.jpg action shot...cant even make it up this. lame.
thanks for looking. don't knock it to much. go easy on me. by the way this took like forever to figure out how to resize everything and post it.
First time crawling cherry popped
Ok so this is the first real crawling action my RS10 has seen. Mods...wing removal...longer shocks mounted on axles...55T RC4WD motors...hb rover whites...pretty much it. steel gears on order as well as hardened pins. I was very impressed with the way this thing crawled. Only ran one battery (stock) so about 20 minutes. Freaking Hot out. I even went upside down in the water but no damage and wasnt very deep. I totally see the addiction to this sport. I can't imagine how well a better crawler and electronics would improve the experience. Definately not comp worthy but still fun. Might have to try it out though just to see how it does. Definately need to do something about the chassis and skid plate. Hangs up alot but 80% of the time I can get out without reversing. Also need to try clocking the axles to see if I can get shocks from hitting the motors. Servo needs upgraded pretty bad.8)
heres a updated version of what ive done sorry for the cell phone pics but i cant find my memory card for my camera...this is the bug
This is the nitro body
I need to get some updated pics with the bronco body also coming soon...
a few more updates....
ZNO-RC wing eliminator
ZNO-RC batt tray
Steel gears- bought from ZNO
8 tooths-bought from ZNO
Hardened pins-ZNO
Outcry dual motor ESC with turbo BEC-ZNO
Spektrum 2.4ghz -CRC
120mm Blue alluminum shocks-Hot racing
Axial links all around-CRC
Hitech 645mg-CRC
Alluminum knuckles all around-Competition RC
CNC machined alluminum rims-local
Rear steer lockouts-homemade
Painted top half of axels and gear housing (still not scratched)
Homade roll cage and windows
Motor wiring mod
