I could be wrong, but I think I know what your problem is. I was just searching the HH site, to determine potential pinions (as I'm considering installing the Tekin ROC412 HD 2300kV motor), and I noticed that the 'replacement' pinion is listed as a Mod1, not 32p. As I haven't actually opened my kit yet, I don't know whether, or not, this is correct. Can anyone else confirm whether the stock spur is 32p or Mod1?
Sent from my SM-T970 using Tapatalk
I think you are on to something. Looking at the part numbers and descriptions from the RBX10 kit instructions as well as descriptions for the same part numbers on popular websites (Axial, Horizon, Amain) there are discrepancies between the part numbers and descriptions. The stock pinion has two part numbers which are not consistent and no mention of Mod 1 in any of the descriptions. The spur gear, on the other hand, mentions Mod 1 on some of the websites, but not all, and not in the kit instructions.
Spur Gear: AXI232055
Kit Instructions: No description
Kit Parts List (from instructions): Spur Gear, 53T 32P RBX10
Axial: Spur Gear, 53T MOD 1: RBX10
Horizon: Spur Gear, 53T MOD 1: RBX10
Amain: Axial RBX10 Ryft 32P Spur Gear (53T)
Pinion Gear: AXIC0843
Kit Instructions: (part is listed as AX30843)
Kit Parts List: AX30843 Pinion Gear 32P 17T
Axial: part # not found
Horizon: Pinion Gear 32P 17T Steel 5mm Motor Shaft
Amain: Axial 32P Pinion Gear w/5mm Bore (17T) (photo of part bag shows part number AX30843)
Pinion Gear: AX30843
Kit Parts List: Not listed. part is identified as AXIC0843 but uses AX30843 in description
Horizon: (forwards to part # AXIC0843)
When i ordered the other pinions to try, i was using the information in the instructions to order the "correct" pitch. No mention of Mod 1 in the instructions, only on some of the websites. Frustrating...
