Post your Battery Finds Here!!
I would say no it doesn't have one simply because it doesn't show it in the pictures, yet some of the other batteries in the pictures do have the balance plugs. I would look for one with balance plug, you don't want to charge a multi cell lipo without properly balance charging it
did it fit in the stock location? or too big? and does it come with balance leads??
and that 250 sounds good.... but seems huge
I still don't have it yet, but the website has the physical size measurements listed. It's just 2 mm wider than the hyperion so it *should* fit the rear axle.
I'll definitely post if it fits or not when I get it.
I picked up two single cell 400mah batteries from my lhs and made a series connector.. the nice thing is that these packs have the same battery connector as the stock battery (i opted for micro deans connectors).. The packs are $9.99 a piece at my lhs, although i bet you can get them cheaper online. The package says "Novs CX/FP". The part number is GPMP0408. They work great! Last forever too.
So is this the reason Hobby King is out of stock on these? So how do they fit and how much run time do you get? What's the mah? Kinda hard to tell on my sorry ass work computer
350mah 2s, fit great. You need to bend the wires a bit so they don't get hung up on the shock springs but no issues yet.
I purchased 3 of these and so far have only used one. I haven't gone through full charge yet in one session. I'm usually done driving before it's dead. I may need to find some other toys to put the spare batteries into! "thumbsup"
x2
these batteries are very nice. i ordered 5 of them for my mrc pro originally. when i got my second micro i needed a lipo. (i traded my last one along with everything i had for it) these fit real nice, and as stated in the post above, you only need one.
x2
Out of curiosity how long does a little 350mah last on a larger MRC?
another possibility?
what about running two of these, one on the chassis and one on the front servo? (I have no knowledge of batteries or RC electronics - 12v in yachts and jeeps is all I have worked with so bear with me here)
http://www.batteryspace.com/li-ionbatterymodule37v500mahwithpcb043144foripodmini185wh.aspx
These are from the iPod Mini and have internal protection from over and dis charging. I would imagine they would charge with a USB cord?
why are people so damn determined to stuff giant battery packs in micros?
just get 2-4 lipos 360mah or less and swap them out as the previous dies out.
this way you have
longer run times in total compared to one giant pack
WAY better performance and handling than a gigantic heavy lipo pack
and also if you go for bigger packs and have only one and it goes bad you are SOL and need to order another pack anyway.
