xigtc
Hi Thomas,
Help me understand what's happening:
Does this mean it works on another channel? Or something else?
Thanks, it was a bad receiver unit! You're control unit works flawlessly!!
Hi Thomas,
heyok, as far as the 3 pos switch controller is concerned, it'll work for a rc4wd bulldog winch for now and latter I can use the same controller for a servo winch correct? Just unhook it from the bulldog and hook it up to a servo winch?
Also, I read the post about bringing a fried servo back to life for winch duty.
I have a Hitec that just jitters as soon as power is put to it, without seeing the servo, do you think your controller could fix it to work as a servo winch? It sounds like it would do the trick.
I will send you a PM! "thumbsup"You still have these? I need one as I am about ready to throw my 645 across the room cause of creep. Shoot me a paypal addy and a cost. I need the 3 pos one and it is going to zip code 60014. Priority mail if you can.
Neil, these work great! I installed one right before last weekends TTC and had no issues at all. No more creep "thumbsup"
I'm about to build my first servo winch with a 7955 and this 3 pos heyok controller. My question is since the hitec control board is removed, the servo pot is out of comission, right? So I don't need to find neutral with the pot and CA glue it, right?
I have s thread in the electronics section that's a sticky.
http://www.rccrawler.com/forum/showthread.php?p=3030312#post3030312
but the only thing you need to do is remove the gears like grizz4x4 says and revoke everything but the motor and solder like heyOK notes.
Basically his controller takes care of the motor and your removing the pin so it does a 360 degree non stop turn.
Yep. Easy as pie "thumbsup"
I can't believe how simple and easy it was to build a servo winch with your heyok controller. No need to center the pot, just desolder, solder, remove gear pin, add grease, and close up the case.
Thanks again Heyok!
Sure did. Have a look here:Did you ever make a controller with a higher voltage ability? I read the entire thread and that you were going to try making ........ soooo before I order one I wanted to ask.
The other day someone wanted to use my controller to operate both a front and rear winch. He wanted a three position toggle switch (with center off) and JST connectors to power his 3Racing (I think) winchs.
This is what it looks like:
