It looks like I've rounded off the inside of dig shaft horn that slots into the groove in the dig shaft, so now there is no resistance. I've ordered a new set.
I have some more questions regarding springs and shocks. I notice in the Losi parts list of hop-ups for the LCC that you can get various colours of springs with different ratings. Does the higher rating mean a stiffer spring?
You can also get different coloured shock pistons. These do not have ratings listed. What significance does the colour of the shock piston have? Is it an indicator of which weight oil to use ? As I see that the different weight oils also come in different coloured bottles. Why would you use a different weight shock oil ?? Do you need to match Spring, piston and oil colour for best results ?
OK I'll stop now ... :roll:
Losi spring rates - lightest to stiffest
A-5144 2.75" Spring 1.2 Rate (black)
A-5144 2.75" Spring 1.4 Rate (Gold)
A-5146 2.75" Spring 1.6 Rate (Gray)
A-5147 2.75" Spring 1.8 Rate (White) - stock
A-5148 2.75" Spring 2.0 Rate (Yellow)
A-5150 2.5" Spring 2.3 Rate (Pink)
A-5152 2.5" Spring 2.6 Rate (Red)
A-5154 2.5" Spring 2.9 Rate (Orange)
A-5156 2.5" Spring 3.4 Rate (Silver)
A-5158 2.5" Spring 3.7 Rate (Green)
A-5160 2.5" Spring 4.1 Rate (Blue)
Pistons - Bigger number equals smaller hole
60 - natural
57 - Black
56 - Red (stock)
55 - Orange
54 - Blue
Shock oils - Smaller number equals thinner. So, 20wt would have faster action than 60wt.
That is the beauty of all the colors and numbers. you can run what ever combination works for you. Slower damping, faster rebound. It takes time and patience to get it right. I still have a lot to learn.
I run..
Springs - Blacks/front and Golds/rear.
Pistons - 56 in both. Thinking about 57s up front.
Oil Weight - 35w in both.
Others will disagree with my setup, but works pretty good. I still need to do more tuning. Sadly, there are endless possibilities with shock tuning. Then you have the angle of the shock (laid down vs upright), then you have inboard upper link adjustments. Both of which will change everything about the shock tuning.
Hope that helps, or blows your mind.
