only_in_a_yj
Do any of the LNCs have the bad worm gears and too many shims installed?
Just purchased a Losi Night Crawler from an individual who only ran it once. Truck still in box got it home with a brand new battery and plugged it in and I am getting no response from the ESC. Please help!
Kv of 3,300 is for the Ballistic Spec, not the Ballistic Crawler. The crawler version has Kv 2,000.18.5 is 1650rpmx12.6v (fully charged lipo)=20,790 RPM
13.5 is 3300rpmx8.4v=27,720rpm
13.5 with a fully charged 2 cell is actually higher speed based on the spec's supplied by Novak.
The easy way is to replace the slip with a non-slip gear (LOSA3172).Im having a helluva time trying to tighten the slipper. Is there any special way to tighten it up on the LCC, ...
Not as such, but with a bit of modification to the body mounts I'd expect most bodies to fit-ish.Are there a lot of available scale bodies for the LNC?
Yes, it can be used.Can you use a lcc tranny in a lnc? How does the dig work?
I don't use the dig... (Can't afford the required components yet.) ... but will try to help.... the cup onto the dig linkage, it seems to now flop to the side when the servo activates. This then fails to activate the dig.
What have I done wrong and how do I fix it?
