RPP posted this. I see the axle panhard mount. Will a chassis panhard bar mount be included as well? If it was posted somewhere else, I apologize.
SSD is putting out some great parts.
Thanks "thumbsup"
The chassis servo/panhard mount is not included with the axle. You just need the SSD CMS kit: CHASSIS MOUNTED SERVO KIT
i assume these have alot more meat in the tubes than stock axial cases.
Yes a lot more material everywhere.
Love this, I want a set for sure, but quick question, What does the optional axle mounted servo mount look like?
It's very similar to the stock servo mounting plate. It sits on top of the 4 link mount. You will need the stock servo posts.
The link mounts are in the same place as the stock axle. So stock links or compatible are fine:
92MM TI LINKS
100MM TI LINKS
TITANIUM STEERING LINKS
No stock SCX10 axle mounts will fit on the SSD axle.
Each axle kit includes a complete axle case plus a 4 link mount, panhard mount and all hardware.
The aluminum servo mount plate is an optional part.
