STANG KILLA SS
~THE SCALE SHOP~
here are some more pics. also a sneak peak of the proto optional alumimum diff cover"thumbsup"
Looks like a welded diff cover from Ballistic, Blue Torch etc.
Is there enough room in the tubes for a custom beeftube for the xr-10 swap? Or can you guys make a splined version for that?
Beef tubes won't fit. The housing is one piece, not halves like the stock housing.
Also the tubes are 13mm OD with 2.5mm thick walls (8mm ID).
So they are solid then all the way down the tube then? Not just a lip where the bearing sits?
