hotrodsoup
Any updates?
Pre-order?
Solid pricing?
date available?
"thumbsup""thumbsup"
Pre-order?
Solid pricing?
date available?
We will start shipping to our dealers next week...
coming soon...
thicker than axial housings
prototype shown
Super scale design
Small OD tubes
One piece housing
Removable diff cover
4 link mount included
Panhard mount included
Stronger with more material at the bottom to wear away over the rocks.
A skid has been incorporated into the design.
Advantages over VP, RC4WD:
A LOT cheaper
Plastic slide over rocks easier
100% compatible with stock parts (RC4WD D44s need all new D44 shafts/parts)
Smaller than VP Curries
edit: here are some more pics. also a sneak peak of the proto optional alumimum diff cover"thumbsup"
See Axial, that's what the SCX10 axles should have looked like since the AR60s came out. Looking good SSD. "thumbsup"
offset front diff would be the tits... also, any chance for AR60-style axle tube ends?
SSD is killing it right now 8)
I would happily pay a little more for an offset version [emoji106]
Will they be getting the "bigger pinion bearing" treatment?
x2, would be nice. "thumbsup"
Check a few posts back, I believe he said it has the 13mm pinion bearing. But double check, I may be getting my threads mixed up.
You are correct, I was just musing that it would be nice. This has not been problem on SCX10 for me, but on Wraith with big tires, the pinion bearings have shorter lives...oh well I pull one seal and add little extra grease before install and change them out as needed. Bearings are only $1 each, so in the recycle bin they go and install new. "thumbsup"
I can't wait for these housings, I just replaced broken stock Axial rear housing in my Honcho.
