Any updates for the lockouts?
Not yet, working on it...
Brass tubes and upper link mounts are ready "thumbsup"
I got a question though as you can see I modified the truss to have the Panhard mounted lower.
Brass tubes for wraith also? You guys are doing some amazing work.
are pics up anywhere yet? I'm looking to see if they are made such that I could do the xr10 mod on these axles. I want to use wraith c-hubs / knuckles but keep a narrower axle.
Not XR mod version.
You get plenty of steering with the SSD Pro knuckles/chub combo and standard axial universals. If you need more get the Vanquish VVDhd inner with wraith outers. I believe that combo gets you near 50 degrees. Hell if your patient SSD could come out with a set of massive steering CVD's????????
Reverse the motor wires. Ideally you want the ESC to still be using forward and reverse in the correct directions.I had to reverse my channel on the radio when I installed the SSD D60 axles.
