Dingo74
Front in place but need to 4 link
Just note the ring gears are on the opposite side of stock SCX's....
I was thinking about the ring gear side and forget which side my kit built instructions put it on. Have to go look at my VP 3-link setup, not sure if that change is good, bad or doesn't really matter....
OK looked at my SCX stock Axial axles and I see that the ring gear is on the opposite side with these SSD housings and that both Axial and SSD can only be run one way not like AR60 where the housing is made to be flipped either way. Motor rotation will need to be reversed to use these.
The crawl space maybe.
Sent from my VS986 using Tapatalk
Ya, I wanted to mention the ring gear flip, as some folks may not have noticed it on assembly. I looked at it and turned my head to the side was staring at it before the light came on.
Thanks for mentioning it, why did they flip it?
OK, so basically it's for looks then? Just wondering because it can't be flipped and if you run one SSD housing, you must run both because the ring gear is on opposite side.
Correct.
Idk why you would run just one :lmao:
I did think about running the rig with just the front done to see how it goes but know now I need to get them both on.
