you can peice together a pretty good rig for about $200 if you take your time
would take some used take off parts and will take more time to build
If you want to use the axles onto the TRX4 or VP, you have to change the steering links. Material: aluminum alloy housing, steel shafts and gears. 1X Assembled Rear Axle. N.W.: Front 210g. 1X Assembled Front Axle.
www.ebay.com
Smooth and running. and stable characteristics help to improve the overall performance. Material: Aluminium Alloy. High-quality materials, high strength and durability, not easy to deform.
www.ebay.com
Center skid plate for the Axial SCX10 RC crawler. This gives you a little more ground clearance to prevent getting hung up. You will also need long M3 grub screws for the lower links on the skid plate.
www.ebay.com
AXSPEED For 1:10 RC Axial SCX10 Wraith Belt Drive Transmission Gear 3.17mm/5.0mm. AXSPEED RC 1.9" Beadlock Wheels Tires for Axial SCX10 II TRX4 Redcat GEN8 etc US. AXSPEED RC 98mm 1.9" Tires Tyre for TRX-4 SCX10 D90 etc 1:10 RC Rock Crawler Car.
www.ebay.com
if you look on alliX you can find these same parts alot cheaper these are just random items i found from a quick ebay search but you get the idea
your bigest exspense is the axles and the radio and tires everything else is in the $10-$20 range
tires can get crazy exspensive but used take offs and chinese off brands are cheap
bodys are the same way ive bought many for $20 and some up to $200
