mikemcE
I thought he worked cheap and wanted to live in Cali :lmao::lmao:Somebody will correct me if I'm wrong, but he gained his "fame" on this forum and I'm sure that helped him get his current position at Vanquish.
those who have these already and if you own or owned a tekin roc412 how do they compare
I figured he was on here somewhere. I just came across his channel last night while searching to see if anyone had videos of the new motors. He's got 20k subs and a intro so he seemed more legit than some random dude who thought the motors were good.
About The SENSORED 1406-3800KV FOUR-POLE BRUSHLESS MOTOR
According to the Castle Creations' website, it says: Maximum Input Voltage : 4S
But on the Specification listed 2S-3S LiPo, recommended.
I am a bit confused, So can these motors really support to 4S power? As I am soon going to order this motor once it become available on amainhobbies.
Thank you
This was an oversight and has been corrected; the maximum recommended voltage for the 3800kv is a 3s LiPo. While the motors are technically rated up to 100,000 RPM, running it on 4s or higher, there is no way to get the gear ratio high enough to keep the motor from overheating in a very short period of time.
If you're looking for a good 4s motor, take a look at the 2280kv or 2850kv.
Thomas Porfert
Tech Support
Castle Creations
The combo micro x and the 2280 with a bec is suitable for a stock wraith.
Sent fra min HTC One_M8 via Tapatalk
Look up a wp Puller pro....
Hang up and Drive
Thank you mikemcE for taking time to replied my question. I actually already had Puller Pro 3500kv. I just would like to give these New Castle's crawler motors a test. For I will buy The Traxxas new coming scale crawler, then maybe I will try to buy these little blue castle crawler motor for testing. I am thinking the new Traxxas scale crawler should not weight more than 8lbs. ;-) Correct me if I am wrong
A Micro-X will withstand a crawling wraith? :shock:I wish I had an answer for either truck. I think it would be fine in both, but I can't say 100% because I have not tested it in either. Our vehicle weights are kinda arbitrary and mostly there to prevent new people to the hobby from trying to put a 7700kv motor in an Emaxx on 4s(people have tried, it did not end well). We are still trying to figure out how to classify the crawler market and suggest good setups without building 50 crawlers and testing every motor we make in all of them. There is so much variation and customization that you guys do to your rigs and so many different driving styles, that it makes it hard to directly recommend specific things until we have more feedback from the community about what works and what doesn't work.
If you are a slow, precise, roll on the throttle type of driver, the micro-x combo will probably work quite well in the wraith, but if you are full throttle, solve everything with wheel speed driver, you would probably want the MambaX and the 2850kv.
