Hi Cabron,
I will measure that stuff and post back here later.
Ill take a ride height bottom of skidplate measurement for you to help with your reverse math lol.
Im not running droop setup, I meant at full suspension down travel.
I'm not Nate, but will give you my 2 cents.Nate wondering if you can help me with what I see as a couple of issues.
1. I bought an ascender cantilever mount and a grundish customs cantilever kit, but the installation was very clunky and the travel seems short. Should the arms from the shocks be longer?
2. The driveshafts are barely connected - I'm running GCM front motor mount, twin hammers 2 speed tranny, and GCM rear truss...shocks up front are 90mm per GCM instructions, and I like the ride height but I feel like these MIP shafts aren't long enough. I can buy another rear long c-drive hub for the front and probably solve the flimsy connect there, but the rear already has the long hub and is still super flimsy.
I guess my questions are is the seemingly flimsy driveshaft connect ok? What can be done about the poor rear travel and clunky movement?
Thanks in advance - all this stuff was done so I could put a full interior in with flat floor.
avgatbest
A Cantilever set up doesn't require as much shock travel to reach the same length of axle travel as a upright shock system, the geometry is totally different.
Clunky, ??? It looks like you are using fuel line tubing to space your rear mount for the shock??? That rear mount for the shocks needs to be pretty solid, or you will loose some travel to a side to side movement instead of up and down. Is that the clunky you were talking about. I would say you need solid spacers back there."thumbsup"
For the MIP shafts, if you have more than 1/4" engagement you should be OK. I put a longer out drive shaft in my GCM transfer case so my MIP shafts had better engagement.
Hope that helps you out a little!"thumbsup"
Ernie,
Is it the grey arms rubbing against the chassis? Maybe add a washer or two in between them. The shaft in the transfer case was something I had in my parts bin. I was thinking axial or ascender link spacers. ( I made mine out of 3/16" SS tubing and use a brake line tubing cutter.) "thumbsup"I'll be honest I'm not sure I'm just using the stuff included in the kit - it's a tiny little piece of thin plastic tubing so that the shock can slide left to right a bit I assume? By clunky I mean the travel isn't smooth at all and the little progressive arm keeps rubbing up against the side of the mount. I expected a smooth travel the way the regular shocks work but maybe it was wishful thinking and a sacrifice I need to live with in return for a flat rear to put an interior in.
What spacers would you recommend?
Also I don't know how much engagement I have, but that idea seems good - can you tell me which shafts you used to achieve that?
I appreciate your help by the way.
avgatbest
Your welcome!
Ernie,
I just want to make sure we are talking apples and apples here. The spacers were a suggestion to used on the rear part of the shock mount, not the transfer case. You would need a 4.93mm hardened shaft for the transfer case. Apples and Apples???"thumbsup"Yeah the grey arm is rubbing against it despite being a spacer between the chassis and the arm. It's actually rubbing up against the shapeways ascender cantilever mount I'm using in lieu of the one that came with the kit.
So I'm confused about the out shafts - you're saying all you did was add some spacers? I have ascender link spacers considering I had to remove them to use the rear truss from GCM anyway?
It seems like I need a longer arm from the mount to the axle, but I could be wrong...I've extended mine as long as they get and if you look closely at the pictures I think they need another 1/8 of an inch to line up identical to the front setup.
What do you think?
avgatbest
Ernie,
Sorry Nate, didn't mean to hijack your thread!!!
Bigchimp, looking at your rear cantilever laydown setup, the geometry looks wrong. The shocks seem a little too long, the cantilever arms are mounted at least 1/2" too far forward causing awkward link angle to the axle. The shocks need to be mounted parallel to the frame rails so that they get a smooth even stroke as the suspension moves, cantilver rocker ratio should be lower too (shorter arm), upper shock mount needs to be bushed so that it doesn't shift sided to side, not just a piece of fuel line. All of this together will definitely cause the clunkiness and non-smooth supsension that you describe. HTH
New2rocks has a great Ascender Blazer build thread here, where he used the GCM rear kit for an SCX10 and it works very well.
http://www.rccrawler.com/forum/vate...big-tiny-truck-built-little-little-hands.html
Ernie, thanks for helping. 8)
I've read that thread - I'll be honest this is my first build but I bought the cantilever kit and the ascender mount kit thinking all I needed to do was bolt it up. I don't know how I can move the mount back any more to achieve the proper angle - I agree it looks screwy, but I'm not sure I did anything wrong unless using the ascender mount from shapeways was a bad idea.
Assume you're using these cantilever shock mounts for the Ascender?
Ascender rear cantilever
by Lampje74
Ascender rear cantilever (5XH7NMNNN) by Lampje74
Looks like the cantilever rocker mount is too far forward and not really any way to mod them to get it in the right spot, unless you slide the whole mount rearward, drill couple new mounting holes in it and screw it back onto the frame rail. Worth a try since you already have them, otherwise you could use aluminum or delrin and cut, file and drill your own pair. "thumbsup"
EDIT: OK looked closer and compared between Shapeways pics and yours, looks like you have the top of the shock in the wrong hole, which causes it to angle out away from the frame rail. Also they didn't supply the rockers? Looks like you need shorter (lower ratio) rockers and it may work out ok after all. Got a good pic with the shock not mounted so that we can see more clearly?
