Thanks, you're using the hole closest to the front to mount the top of the shocks? That is the upper shock mount needs to com forward so that you can get the shock in close and parallel to the frame.
They used steel Traxxas link mount ball as upper shock mount in Shapeways pics.
Definitely need shorter rockers.
I'm a little confused because the shocks ARE parallel to the frame when everything is bolted up? Am I wrong?
Below is an incredibly technical diagram indicating which bolt the spring shock end is being mounted to per the shapeways pictures. "thumbsup"
