Yes i thought it was a machined link as well. Im assuming they did it this way due to tolerances with the threads. A tiny shim can make a big difference on how things line up. I wonder how plastic rod ends would do.Really? They sure didn't appear to be an allen stud with a threaded spacer. Shit I could have made those for WAY Less than the 11.99 a pair they were.
They Look like they are machined links. Thats kind of a drag.
Good info, thanks!A black plastic spacer would be better since it would give a little. It just would not look as bling. If I were doing it again, that would be the route I went. The link/set screw is 25mm and the spacer is 8mm if anyone is interested in making their own.
I assumed the spacer was going to be some weird, custom size, not a plain, old 8mm. You can get those from McMaster for $2/piece and probably under $1/piece if you willing to wait for some generic version to be shipped from China.The link/set screw is 25mm and the spacer is 8mm if anyone is interested in making their own.
VP has a link that other are using. its the short link that comes in the 2 link pack for the Shfit linkages on the VFD Twin I think it is.Yes i thought it was a machined link as well. Im assuming they did it this way due to tolerances with the threads. A tiny shim can make a big difference on how things line up. I wonder how plastic rod ends would do.
Hopefully Vanquish comes up with something better. Maybe something like Htech but with adjustable tension like their rod ends.
That's one way. I would have had to buy 6 kits though since I'm doing a a 4ws and a normal 2ws.VP has a link that other are using. its the short link that comes in the 2 link pack for the Shfit linkages on the VFD Twin I think it is.
But you have to buy 2 packs to get 2 short links, or 4 for 4WS rigs. be nice to see them drop a pair of those with Rod ends and just sell them as an upgrade package.
Yes, but that link doesn't appear to fit perfectly either. I've seen spacers, spacers, lock nuts, etc. used with those shift links.VP has a link that other are using. its the short link that comes in the 2 link pack for the Shfit linkages on the VFD Twin I think it is.
I have one of those scales and it is less than accurate. You can't really make repeatable measurements. It varies based on how you set the vehicle down and if one shocks is compressed more than the other it throws everything off. I don't know how to rectify that.May as well put these fancy scales to work and get a baseline. This is my son's rig ready to go with a 2200 mah 3s pack. For the TLDR crowd, this is a kit with lightweight trans gears, fusion se, 35kg Amazon servo, Chanquish Methods, 5.25 TSLs with Injora silicone inserts.
Fairly balanced left to right. A little weight up front will get to the 60/40. Might just start with a brass servo mount.
You'd have to, or lockout the suspension by some other manner, in order to get an accurate reading on my scales.Just a question from way back in yesteryear - shouldn't you undo the shocks to get accurate corner weights (maybe you did?)?
