My late dad's CC01 re-build
Great job so far! It's cool to see a retro car brought back to life. Can't wait to see more.
Cleaned and buffed the windows. The stains couldn't be removed with just soap so I had to rub it down with buffing compound and a buffing machine.
Before:
After
Sprayed 5 layers*of clear gloss top coat.
Will wet sand and buff tomorrow once the clear coat is cured and do the window side panels, mpulding, grill, door handles and rear plate garnish with flat black. Then install the lights.
So I wet sanded the entire body and 3-step buffed it.
Wet sanded...
*Buffed...
Seen here are the metallic flakes...
Prepped for masking (again)...
Painted all the parts that should be in matte black
Mask off...
Finishing touches...
Tri-diamond emblem painted and some panel lines.
Fabricated the lens for the tail lights. MAde some grid lines, repainted to clear red and added frosting too
Finished body and lights installed too...
Now mounted on the chassis...
With lights on...
WOW! Fantastic job on the body! It turned out great. Nice detail on the black trim and the lenses for the lights. Nice metallic flake, I didn't notice that before.
Thanks! I mixed a few drops of silver on the Teal base color to make a metallic finish. For stronger metallic effect, just add a few more drops depending on your liking. But for pearl finish, the silver has to be mixed with the clear top coat.
That paint looks great! Wish I had the patience haha
So some parts arrived yesterday...
Rear suspension link, aluminum shock and suspension link mount, aluminum servo mount, bead-lock metal wheels.
Installed...
Aluminum servo mount...
Bead lock wheels...
Installed a fan for the motor. I fabricated a CF plate to mount the fan onto it...
With the new wheels...
Still waiting for new aluminum parts for the front suspension and YR aluminum steering set.*Will update soon.
So I've had this pair of shock mounts since last March and I have never really decided whether to use it or not.
I was contemplating on creating holes on the rear part of the chassis to install this but the 100mm shocks doesn't need to stretch out in the back like it needs in front. But since the original mount of the CC01 is plastic, I decided to use this aluminum mounts and place it sideways. In that way, it can be adjusted to many setting. Forward, backward, higher or lower. The result is great.
I also installed strut bars using some spare adjustable links I had, front and rear. It actually helped a lot in stiffening the chassis.
Bought new sets of 100mm (grey) and 110mm (blue) shocks to replace the front dampers. The middle one is the nicest of the three. Better rebound and very smooth damping.
The ESC and servo are waterproof but the RX isn't. So I ordered a case for the RX and fabricated a new ESC tray from a 2mm carbon fiber plate. Re-arranged the wires and concealed what I could to make it look cleaner.
Went crawling today with the bigger crawlers (Axial, Traxxas, AE, etc). My CC01 was surprisingly good. Although it couldn't crawl up the very steep areas but it still manage to get to most areas in the mini mountain.
