So I started on the mods by installing the
Axial NVS Night Visions System. I bought an additional
4 single LED light strings to for the rock lights and a
double LED light string for the front bumper lights.
I have to say, this is my first crawler with a fully decked out lighting system and that is because I suck at wiring up LED's. I was dreading either the cost of a comparable "rc-lights" system or building my own light setup until I found out Axial came out with a light system that has everything I wanted at a reasonable price IMO.
My initial thoughts on the NVS is Axial damn near hit a home run with it. The only thing I am not a huge fan of is the blinker lights / functions. We all know when your crawling your never going to use your blinkers unless your accidentally hit the turn signal lever when turning left or right. If they could make a crawler version of this NVS system that removed the blinkers LED's and blinking function from the control box it might bring the cost down even more and also free up another port for additional rock or off road lights.
I mounted the rock lights using some Dubro steel landing gear straps, they were the perfect size. All I had to do to the straps were drill out the holes to fit the 3mm screws and add a slight bend to one end to give the right angle I wanted on the lights.
Here are some shots of all the chassis lights installed.
Axial NVS Night Vision System
Single LED light strings for the rock lights
Dubro straps
Each of the light buckets that come with the Trail Honcho comes with LED retainers
Rear rock lights
Front rock lights
Front bumper lights and rock lights
Rear tail/stop lights
Chassis lights wiring, I'm going to make a mount for the transmission to mount the control box on.
