at Fungi pic, bro what frame is that ? moded trail trekker?;-)
are they a direct bolt up to the Micro Crawler?
Pool all your lil tweaks and mods and why you did them!!
I just got 2 of these last night and have been goin back and forth through the forum to find all the MODS! so lets get them all in one Place.
Remove or shorten shock springs. helps suspension and COG (I spun 4 coils of the spring off the shafts to shorten them)
Re-mount battery and ESC to the axels. this helps COG.
De-foam and weight wheels. gives beter traction, helps COG (i used 12'' of solder)
flip the tranny, shifts weight forward.
Get lipos, better runtimes and increases speed and power.
i have done all but the Lipo."thumbsup"
what you got?
I agree, replace the gears, which is the real problem, don't "mickey mouse" the cover. Just a matter of time before those "mod" covers cause broken gear teeth or buggered bearings :idea:
-Lengthen wheel base using Mini-T suspension links.
-Then use Trail Trekker driveshafts to lengthen driveline to fit.
-Stack Gen-1 XMODS blue and red springs. Lowers ride height but are soft enough to completely compress.
-Li-Po!!!
-Rear Steer. You have to adjust your driving, but the added maneuverability is worth it.
-New rims and tires. I'm going with Miclaws and BWD's wheels, haven't got them yet, we'll see how they work.
Don't forget the BWD widener kit, you wont be able to turn otherwise.
Here's one I haven't seen mentioned before. I removed the bottom of the servo case, drilled a 1/8" hole in the center, removed the plug, routed the wires through the hole and replaced the plug. This centers the wire between the shocks and prevents the wire from effecting the suspension travel.
