johnnyh66
Scale Detail Engineering
If using the Mini T rod end mod: Drill a hole through each mini t plastic cup. This allows easy access to the .05 hex inside for adjustments and maintenance.
everyone talks about wrapping coils of the spring around the top & bottom of the shock....
I must be stupid or something 'cause I can't for the life of me figure out how to do this!
Can someone describe it, step by step?
Here's one I haven't seen mentioned before. I removed the bottom of the servo case, drilled a 1/8" hole in the center, removed the plug, routed the wires through the hole and replaced the plug. This centers the wire between the shocks and prevents the wire from effecting the suspension travel.
How are you removing the tire foam? Do you cut the tire as close to the rim as possible or does something like guegone (mentioned earlier in the thread) disolve the tire glue enought to get the tires off without cutting/damaging?
I am a noob and picked up the micro 4x4 trekker a couple days ago ...a little nervous about pulling the tires from the rims to remove foam and add weights/bb's since my lhs doesn't have replacements in stock ...unless I get the kind that don't require glueing the tires ... are those worth spending the $ on?
Sorry if these are dumb questions ...any info is appreciated (or pointers to posts that I haven't found yet).
Pool all your lil tweaks and mods and why you did them!!
I just got 2 of these last night and have been goin back and forth through the forum to find all the MODS! so lets get them all in one Place.
Remove or shorten shock springs. helps suspension and COG (I spun 4 coils of the spring off the shafts to shorten them)
Re-mount battery and ESC to the axels. this helps COG.
De-foam and weight wheels. gives beter traction, helps COG (i used 12'' of solder)
flip the tranny, shifts weight forward.
Get lipos, better runtimes and increases speed and power.
i have done all but the Lipo."thumbsup"
what you got?
Has anyone used this battery?
http://www.amainhobbies.com/product...cro-Heli-Airplane-25C-Battery-Pack-74V-240mAh
I have a Trail Trekker and was hoping it would fit on the rear axle. I tried measuring and it looks like it will be close.
pretty sure theyre the same sizeI have some batteries that are 22mm wide and they BARELY fit between the shocks of my micro crawler, I am not sure of the dimensions of the Trail Trekker though. I have a Thunder Power 7.4v/250mah pro lite v2 that is 21 mm wide and clears much better.
There actually not the same size, the Thunder Power is 1 mm thinner and it does actually help with situating things.pretty sure theyre the same size
at Fungi pic, bro what frame is that ? moded trail trekker?;-)
