I've only broken one shock and I have 3 crawlers. I use XMODS springs to soften the ride and they work fine for me, so I never went with the HR shocks. As for the chassis, different people will have different opinions. The only opinion I can offer is to not buy Hot Racing's chassis. Looks cool, but doesn't really do anything for flex or lowering CG. The Blade and Ridgeback chassis are very popular.
Thanks!
Ok, so far this is where I'm at with my Trekker.
HR Gearbox <~Arched out the battery cradle to accommodate the larger gearbox
HR 56t Spur <~Glued to the clutch plates
The HR Gearbox & Spur should be your first Mods. The plastic gearbox is total crap. Mine was hosed after 15 runs on the carpet with the stock battery and no abuse. One of the 2x5 bearings had melted into the housing and the clutch plates were warped causing the spur to wobble like a mofo. I took Dan's advice and glued the clutch plates to the spur. Having two plastic plates hold your plastic spur is stupid. Its doomed by design.
HR Steering Link <~Steering is less spongy and clearance is much better on both top and bottom
DDT Predator 90-Turn Motor <~"THE BOMB"!!!!! Ever see "Crazy Mary, Dirty Larry"?
Hanks: [walking through police garage] Stevie! Stevie, ma boy! Where are ya?
Steve: Hey!
Hanks: Where the hell's that car at?
[referring to high-performance police car]
Steve: Over here... but she ain't got any siren or lights yet.
Hanks: Hey look, all I care about, is what you've got under that hood.
Steve: Take a look
[starts police car, car rumbles to life]
Steve: .
Hanks: [smiles broadly] So, what's my top end on this?
Steve:
Unlimited.
Gobs of torque and decades of battery life. And with the LiPo??? You go fiddle farting around with all the Sanford & Son tinfoil chassis, rubber bands, BB's, and springs from a bic pen all you want. This is my recommendation for the number three must have add on johnny after the HR Tranny and Spur!
HR Gearbox Cover
Delrin 11t Pinion
HPI Goop for the Gearbox
Gear Head RC 8Trax Micro Crawler Wheels
rc4wd Rock Crusher Tires
Losi 300mAh LiPo <~Fits Perfect in the stock battery box and my choice for the number four must have add ons
Hi-Tec HS-5065MG <~Servo Mounts need to be taken down to flat to accommodate the 65MG servos
HR Chrome Body Clips <~These are great, they slip on easy. And the loops are bigger so you can grab them.
One Large Chrome Body Clip <~18 or 10 scale I imagine, is great for the battery box. You will be able to leave your 10 foot needle noze in the toolbox when you wanna remove the battery
(50 @ 5 Balloons) M2 Steel Locking Hex Nuts from RTL Fasteners <~Ditch those ghetto plastic wheel nuts and use one to top off your slipper when you rebuild your Tranny
So far everything I have done with the little Trekker has been fantastic except one. The "Rock Crusher Tires" although nice looking and a tad bit better at climbing are a dissapointment for me. The tread pattern is deep enough but too smooth and lacks adequate grip on the side walls.
I'm not sure if I wanna try pulling them and taking the foam out or just waiting until I get a new pair.
I guess Losi aluminum chassis Hop-Ups and HR shocks will be next. I keep looking at aftermarket chassis but the only thing that looks mildly attractive are the rc4wd scale units but I don't want those stiff azz leaf springs.
What is the absolute Top Dawg tire for crawling? My rims are 1" I believe.
Sent from my BlackBerry 9900
