Thomas Porfert
Can somebody help me get my 4px setup? I can't seem to get it right? Have the mmx setup with crawler mode over 10%. It is always in crawler though no matter where i turn the dial. If i unplug the aux wire it goes to rock racer.
Make sure you have the brake/reverse type set to "With Reverse" or "Without Reverse"; if you have it set to "Crawler Reverse" then it won't switch the reverse type to the Rock Race mode.
If it is already set for With or Without Reverse then the radio signal isn't going low enough to engage the Rock Race mode; to fix this you will need to increase the value of the low endpoint on the auxiliary channel.
Hope this helps!
Thomas Porfert
Tech Support
Castle Creations
