willyg1981
No that’s the front out drives you are drilling out the drive shaft , connection between d/shaft and pinion which is a through hole , if you drill out and mess up the thread you need to replace the d/shaft no need for replacement outdrive , as long as you get a good tight hammer in and plenty of heat it should unscrew
