Traxxas TT and Losi Super Baja Rey specs back to back:
SPECS
Length: 27.32 inches (694mm)
Front Track: 13.57 inches (345mm)
Rear Track: 13.57 inches (345mm)
Ground Clearance: 2.27 inches (58mm)
Weight: 13.4lb (6.1kg)
Height: 10.29 inches (261mm)
Wheelbase: 16.53 inches (420mm)
Front Shock Length: 5.19 inches (132mm)
Front Threaded Shock Length: 5.19 inches (132mm)
Rear Shock Length: 6.3 inches (160mm)
Rear Threaded Shock Length: 5.55 inches (141mm)
Tires (pre-glued): 134mm x 57mm BFGoodrich® KR3 replicas
Wheels: Dual-diameter 40mm x 56/81mm
Speed Control: Velineon® VXL-6s
Motor: 2200kV
Losi Super Baja Rey
Losi Super Baja Rey
Type
esert Truck
Scale:1/6
Length:30.5 in (774.7mm)
Width:15.6 in (396.2mm)
Height:11.0 in (279.4mm)
Ground Clearance:3.0 in (76.2mm)
Wheelbase:19.5 in (495.3mm)
Weight:19.45 lbs without batteries (8.8kg)
Chassis:4mm Plate, 6061-T6 Aluminum
Suspension:Independent Front/4-Link Rear
Drivetrain:4WD
Motor or Engine:58 x 88 mm 1200kv Non-Sensored Brushless
Speed Control:Included
Radio:Spektrum DX2E ACTIVE with AVC
Servos:Included
Batteries
2) 7.4V 5000mAh 2S or (2) 11.1V 5000mAh 3S LiPo Battery with EC5™ Connectors (Sold Separately)
Charger:Sold Separately
Gear Pitch:1.5 MOD
Wheel Size:2.9/4.0 in One Piece x 2.1 in (53.3mm)
Kit/RTR:RTR
Shock Type:Coil Over, Oil Filled Shock
Body:4 piece, Screened
Ball Bearings:Full Ball Bearings
Is Assembly Required:No
