I was the one that posted the 14mm but I was brain farting and thinking of our V2 AR60 axle. I believe we actually DID go to dual 5x16x5! I've just got too many projects in my head...
My AVC RX died today.
Went crazy with the servo. Randomly jittering and moving back and forth.
In the TH ch of the RX the RR was moving the wheels back and forth randomly with no input.
There was a tiny bit of dirt and dried grass in the RX...waterproof huh...
Awaiting a warranty claim though I've gone for a non AVC RX in the interim as I just want reliability.
Update:
The RR seems to drive better (i.e. tracks straighter under power, is more nippy and responsive at the expense of a bit more tramlining) without AVC. It also seems more fun TBBH in my limited testing thus far.
Interesting. I had a trail run today and about 3/4 through my servo starting glitching like crazy, sometimes not accepting input. I thought it was cause I accidentally submarined it 10 minutes prior, ended up carrying it out of the park. Got back to the truck and plugged my battery back in. Starting working fine. Can't figure out if its my servo (Savox 1210SG WP or receiver). Just pulled my waterproof servo and packed it with grease and put a few layers of con formal waterproofing on. My AVC has been disabled already. This is making me think I should just yank it now and get something else in there.
Its likely the receiver.. I exposed my Baja Rey to a little too much moisture and it went nuts.. Turning full lock left or right on its own and at random, I ended up having Horizon send me another under warranty..
Anyone else rear DS grub screw/pin locked up? I tried heating it up with my soldering iron at 900 degrees and still won't loosen and Im not trying to break it either since that seems to happen to most people. Any other ideas?
I drilled mine out. Im working on a steel drive shaftAnyone?
