What up guys, just wanted to introduce myself as a new Baja Rey Owner. Its been over 15 years since I've been in the hobby and WOW how things have changed (Used to have a HPI Nitro Rs4 and Ofna 1/8 Nitro Buggy)
Initial thoughts:
- Truck is beautiful, love the details
- Running 3s and this thing is crazy fast and handles very realistically.
Disappointments:
- Front steering servo is weak (What did you upgrade to?)
- Grinding sound from gears when starting from a stop/very slow speeds
- Owners manual doesn't have much info. Not sure what the plastic bar is for.
- Car seems to have over heated on my first run as it basically shut itself off...what can be done about this? *Edit* It appears the battery was just dead? Do Lipo batteries just turn off once they are dead?
Also a newb question here:
- I am new to electric and learning all bout the batteries/connections. I ordered my truck from Amain hobbies and showed the customer rep everything I was ordering (Truck, charger, battery) and he said this is all I need. I specially asked if I needed another connection for the charger to battery, but he said no. Of course when I get my truck, the plug is too large for the battery. Apparently the battery is IC5 while the charger is IC3. I ran to my local hobby store and grabbed the connection.
- All charged and ready for my first run, and I see the trucks plug is also IC3. I thought, no big deal, I have the connection from the charger I can use. Well when using the connection, I have way to much slack of wire that does not fit in the battery box...what are my exact options here besides buying a different battery? Real disappointed with Amain as I asked TWO employees prior to my purchase and both said I have everything I need to run.
Appreciate the help guys and I look forward to learning more from the forum and its members
- Mervon
Hey Mervon, Welcome to the Addiction again (Crawling is a bigger addiction that other RCs. lol Trust me when I say this. lmao) I got out in 2012, and just got back into the scene. I do not have the Baja or Rock Rey rig. YET.
But I can help with some of your questions.
To start, yes, the technology of Brushless Motors and LiPo/LiFE Batteries have seriously changed the market for ever. For the Better no doubt.
As for your questions.
Just like back in the day. Stock Gear is just enough to get it done in most all cases (not always, some rigs have some good electronics, but they are just very few and very far between)
A Lot of people are using Savox Servos. With today's Coreless/Brushless motors and LiPo/LiFe batteries. gone are the 5 minutes of fun, and 15 minutes of draining the NiCD/NiMH pack to charge up for 5 more minutes. lol
I get hours of crawl time on a single 2S 5200 Turnigy Lipo in my rig.
I am liking the Reefs RC servos. Their 422hd V2 servo is just about 100.00 and on 2s will provide 422 in/oz of torque for your rig.
I used to be a JR Servo Snob (just loved their quality and reliability) but they were generally 30%ish percent more than Futaba Hitecs of similar specs.
Many use the Savox servos with great results.
Just be sure it has a minimum of 300 in/oz of torque for steering these rock rigs. with the tires pinched in rocks, you'll need some good torque to move them.
The start up/slow speed grinding noise could be a few things. if it goes away at a bit higher speed, that tells me the gear mesh is probably good at the pinion/spur. If it was too tight, the grinding would continue on higher speeds.
Depending on the gearing, it may just be a tight set of gears working in (news gears may need a lil runtim to smooth out.
But generally, these rigs are not quiet or silent with running slow/low speeds. The gears (some are spiral cuts ) make a bit of noise normally. so you may not have a problem, but a more normal gear train. Watch some vids of other reys and see if yours does the same, or worse. May help clue you into if there is an issue. and what it may be if there is one.
Most Manauls are great on Pics, but very space on info. Best I can offer here is to scour that manual and find the pic of the bar you reference. It would show you where it goes. A Pic here may help others help you on the bar (what bar is it, what it looks like etc).
These New Electronics for Brushless and Lipos have some built in fail safe features.
This can get pretty deep for info on LiPo Safety. But to cut to the chase, Lipo cells are flat (out of charge) when they hit 3v (3.2/3.4v per cell) and it's Time to recharge. Fully charged they give out nearly 4v.
when Lipos get Undercharged or overcharged, it can cause an issue, and that can lead to not good issues (beyond bad cells, a LiPo can ignite and flame out due to being to far drained, or over charged, or even the cells getting out of balance can be a big issue.)
So New ESC's have LiPo Charge Monitoring. and that will shut off the power to the motor via the ESC when it notes the cell charge is too low.
You'll have a bit of a learning curve on LiPo charging and Balancing to get caught up on, and from there, the ESCs and programming them for your LiPo batts. Its not a hard curve, its pretty easy to learn. But the Differences in these new LiPo cells is worth learning the ins/outs of LiPo Batts.
Basically it sounds like you're ESC shut off the power to the motor as it sensed the charge was low. at this point, it should like the ESC did what it was designed and programmed to do. Shut down power so you can't keep driving and further drain the LiPo battery.
Here is a vid that will help get you up to day on LiPo batts.
https://www.youtube.com/watch?v=lQtKgiv70DQ
The connectors used today are many. Not like when we had basically one or two connectors. Today there are T Plugs (Deans style) EC3/5, Traxxas has their own, XT 30/60/90 connectors, as well as bullet type connectors. So this is a bit of a haphazard area where the majority of us guys will buy a bunch of one type of connectors and use them on all our batts, escs, and Charge leads.
I know the Vid is from A main.lol But it is solid info.
