I want to add a warning light to the Unitrac. My first thought was to place it on the roof of the cab, but i didn`t like to run the cables inside down from the roof, because they would be hard to hide.
I found a pic of Mog with a warning light in the back:
I like the way it is attached to the cab, even if my version will not be extendable.
So I started making some brackets from small rod ends:
some brass tube:
And, of course, a LED. This is a flashing amber LED, so I need no further electronics (beside a 150 Ohm resistor):
Plastic sleeve as adaptor for the tubing:
Resistor in line with the LED ...
... and servo plug, so this can be powered by the receiver or rather by a HEYOK switch, so it can be turned on and off by radio :ror:
Attached to the cab using two 2mm screws:
I will take some outdoor shots at the weekend.
