Re: Krawl's "SECRET AGENT"
Thanks for all the compliments.
I wish I had more time on the motors, as I had other stuff I was doing to the endbell to lose more weight, but time, design goof on my part on the other timing ring, and the mailman made those NOT happen on this version....they will be on the nats motors.
A quick note, the lightweight spring posts are not in that pic. I forgot I had them and I installed them after....
Egressor hit the nail head on some stuff....the motor will see a powerband change. I don't think there will be much worry about heavy binds. I am mostly concerned with loss of drag brake really. 4 magnets already have a weaker drag brake, so losing more steel will effect it some. I don't think it will be as bad though.
Notes on the mods
Ground, Polished, and Dyed stacks - This is done to make the airgap gap precise, so there is little worry of getting a notchy feel from an imperfection in the laminations, which happens since they are stamped.
Lathed Can - Purely a weight saver, but sure does look pimp! It's going to add RPM and Power, but as noted we expect some torque and drag brake loss.
Timing Rings - This is an older idea I learned from Oscar Jansen at Cleveland in 2004. He showed me how an Aluminum timing ring can add RPM with basically no torque loss really. I went home and had a local make me timing rings out of all sorts of materials. Brass, Bronze, Aluminum, Titanium, SS, and Carbon Fiber. Most were lost over the years, but I luckily found the Aluminum ones while making the new Carbon ones. Good thing, as the Carbon Fiber proved to be a challenge with the other mods I was trying to do! We are using the Aluminum to save weight, even though the ones in Jermeys motor are twice the thickness as a stock one, they weigh half!
Lightweight Spring Posts - No change in motor performance, purely weight...about a gram per pair savings.
I will be offering many of these features as options on current motors......how soon depends on parts suppliers. The only ones for sure at this point is the can turn down and polished arms, as I have a local machinist willing to do the cans and I do the arms here. I am still working on some details for it though.
The timing rings, spring posts, and other lightening methods (some of which did not make it on this motor) are ALL in the works, really just figuring out suppliers.
While the can mod looks like something you can do at home with a lathe, you better have a zapper available or you won't be pleased with the results....better know the tricks to cleaning out the motor too
A ton of work went into these besides all the mods and such. I was very anal about the assembly, using stuff I have not done on a motor since the racing days. Probably overkill, but I figured what the heck......pulled a couple of late nights to get them all done.
I've already got a LOT of PMs and emails about a set of these motors. I can't fully replicate them at this time, as some parts were the ONLY ones I had....the cost on this pair of motors would be nuts too. Figure Jermeys old motors were these minus all the mods and lightweight parts.....they were about $265 a set. These will easily be over the $300 mark!
I leave you with some other pretty photos.
The unused carbon timing ring.
The initial batch of cans done on the lathe (yes, 8 KR cans, 2 TI, 2 Cobalt, 2 Checkpoint, and 2 Trinity)
Later EddieO
