maybe a side hilling comp to go with it too...it would be very interesting what setup works on incline and side hilling.
agreed. side hilling is one area i haven't really worked on with my rig yet.
so i saw lazy's thread and it got me thinking. i don't have any other crawlers to compare to but i still feel like i'm getting too much TT. i'm looking for suggestions of things to try. when under power the right front does try to lift up. on my traction board the right front is lifts to the point it is barely touching. so help i've attached a bunch of pics of my setup. could it be that i need to raise the mounting point for my front top links on the chassis end?
hey jebster i think your rear links are fine where they are at, what you should try is raising the chassis mounting points on your front upper links...if you figure it out let us know and good luck bro"thumbsup"i'm curious if anyone has a short video of their rig and how much TT they have? given this is my only crawler i don't have a comparison point. i'll try to do the same later tonight.
i think my rear links are probably in pretty good shape (i can't spread them much more given the saddle pack i run on the rear axle). i was more curious about my front end. i've looked at other threads and many people have the same link placement on the uppers where they meet the chassis. this is why i'm wondering what a "touch of TT" looks like. i think i will try moving the mounts further up the chassis to see if that helps.
venomcrawlerdud, my front springs are pretty soft so i might swap them out for a little stiffer set.
you need stiffen (loken at the front) the left front shock a little more the the right so it is trying to put more pressure on it the the other side so in theory it keeps it down
and looking at the back stiffen the left rear so it trys to shove that front corner down some
i have my front links rasised front he stck points on Adams plate mine ar close in front but high up and try to lower you rear links on the chassis
venomcrawlerdud is right its about link geo you want the front uppers as low as can be on the axel and as high as you can on the chassis. on the rear you want to be spread apart as much as you can and on the axle high up and and on the chassis low. i have very minimal TT soft springs in the rear and super soft springs in the front 25wt oil in all 4. the whole stiff spring in corner is just a bandaid fix and I think it affects the rig in in a bad way.
everyone's assessment that i need to raise the front upper chassis mounting point confirms what i thought (thomas, thanks for the more specific 3/8 - 1/2" recommendation) and i'm going to make some changes.
by the way, is there any way to post video clips via the forum or does it have to be done with links to services like youtube?
oh yeah, here is a pic of my rig with my son's maxstone 16 that santa brought. My creepers little brother!looking forward to upgrading it with a mvp chassis from ab design's (thanks adam) and using the things i've learned about link geometry on this thread to improve his rig.
so i made a mod to my chassis to raise the front upper links chassis mounting point. haven't done much testing yet but i hope it helps to further reduce TT.
