rmdesignworks
The only thing Ive done to the front end on mine is to spread the front uppers a bit at the stock location on the axle and I added a 5mm spacer inside the chassis which brings the uppers a little closer to parallel. I also put about a 30 degree bend in them to help clear the OTA steering links and the shocks...this make them bow inward a bit. Total angle was changed with about 12 - 15mm of spacing changes if you only did it at one end or the other.
Im glad the diagram helped.
