When I first got the itch to get back into RC, I was searching for new trucks that had been released during my hiatus. The plastic Vanquish rigs kept coming up so I started comparing the Fordyce to the Phoenix. My first Bing search (Bing before Google for the rewards) of "Fordyce" gave me a NSFW shock. I saw bump man meat. :shock: Oh Vanquish this one was an epic fail even if the truck is named after a trail in California. I guess whatever happens on that trail stays on that trail! :lmao: The double entendre (ohhh fancy word from grade school) here is the bumpy road I've had over the last few years.
I preferred the Fordyce over the Phoenix because of the straight axles. My last few rigs pre-hiatus were portals I believe. Plus, the Fordyce has a simpler transmission and I do not think I will need the adjustable overdrive or dig.
So while I was waiting for delivery of my VS4-10 Pro Black, I ordered a Fordyce on sale along with parts. Looking back I should have ordered the lightweight 21% OD not for weight savings, but for less rotational mass in the drivetrain. This would have made for easier "spool up". I am also not sure I would have spent the money on the S8E shock parts as those seem to be hit and miss shocks. Thoughts on these shocks from those of you that have read this far???
First order of business was changing the wheels. This would be obvious to anybody that knows I have a tire and wheel addiction. Vanquish discontinued the Roost wheels, which I always wanted, but never pulled the trigger on, so China to the rescue.
What the stock truck looks like for those of you, probably less than a few, that do not know.
Not a bad looking wheel and tire combo. The tires are shockingly sticky for an RTR.
Good news is the Incision 0.8" wide brass wheel clamp rings will fill the Choost wheels. And the Fanquish aluminum wheel clamp rings will fit the stock, plastic KMC Riot wheels.
Ohh pretty! :mrgreen:
Yes, these images were taken in my kitchen and dining room and I will most likely continue that way. I live in this house by myself at this time so it is like a bachelor pad.
I found a Turnigy 2S 4200mAh stick pack that I have for my Tamiya RCs. Somehow it still had 7.94V in it so I was able to do some pillow crawling in the living room. The stock electronics leave something to be desired. Maybe a healthier battery or 3S will help. I am guessing this truck will need a better ESC, Motor and servo. I can probably live with the radio.
I have a couple of questions to start.
1. Again, any thoughts or tips on the S8E shocks?
2. Does the Phoenix interior fit the Fordyce body?
3. Do the brass tubes for the F10 portal axles fit inside these straight axles?
4. Any feedback on using the lightweight front VFD gear set and/or 21% transfer case underdrive gear set?
5. I will probably stick with the 21% OD kit for this truck, but do you guys have experience combining this with rear underdrive gears? Would probably be overkill for trailing. Thoughts?
