Thanks...it seems to like this stance more as well "thumbsup"
All of the links on this rig are a direct swap over from my Spec Ops. I had the bends in the front uppers to clear the battery, chassis, and motor. I'm running the MFD upper link mount on the front, but I've modified it to move the links as far forward as possible and to mount them at the lowest position possible. All of that adds up to needing to have multiple bends. I'd actually like to grab a set of straight 1/8" uppers and see if they'd work out.
And the skid height?
Looks good!
I would even guess you could benefit from putting a bent end on the axle end and moving the shock to the outside of the tab.
I like a decent amount of angle on the rears and as little as possible on the fronts. That could change with spring preference though too.
Pinks all the way around. Maybe a touch stiff in the front, maybe a touch soft in the rear but its pretty close.
You get a 9380 yet?
I hope to see this at the next comp "thumbsup"
