flapjack
good job rodney those pics look great "thumbsup" and thanx ty...i went looking around but apparently im blind lol
i used the stockers in the forward position...with light oil and a stock spring...and the outer was the ax10 shock...heavy fluid light springAll four ax10's or did you keep the stock mini's?
I used Traxxas XXL shocks in the rear position. No spring on them, 70 wt oil, 3 hole pistons. I had to also use an HPI Savage shock end to make the shock longer.What length shocks are best for a dual-rear set-up? I've read the Blitz shocks are a good option. Any opinions?
On the rear, the rear shocks need more travel. On mine I kept the stockers where they were but put in some 70wt oil, then I added some ax-10 stock shocks with no springs and put 70wt oil in those as well.
the rear shocks need more travel..
More travel and more dampening for the hard "slap" landings.
I just emptied and filled my stock shock with Losi 50...I'm also moving them to the rear before I go dual shocks.
Wait a minute...this really limits down travel. Going with XR-10 shocks on the rear.
It's hard to explain what I meant by the rear, rear shocks needing more travel, so I'll try again here.
I am usually very patient, but reading all the post is making me crazy!:lmao: I want to start working on mine right now.![]()
I'm surprised it took you this long to order one :ror: I ordered mine as soon as I saw Rodney pulled the trigger.
Took mine out today during lunch. The Holmes Hold works great!
Ahhhhh, more victims to sacrifice to the rally gods. :ror:You guys are in trouble now, you will have me spun out to drive around now. lol
Good to see you got one going. The more cars, the more races, the more races, the more laughs. "thumbsup"
Not a bad idea Shon. But do those tires have any traction? The almost look like slicks.
What about the BFG all terrain clones or the prowlers? The track conditions are really loose and taller tread might work better.
For instance: The Tamiya Rally blocks with their tall tread seem to hook up better then the HPI rally tires with their smaller lugs.
If you guys want to start playing with different tires we can just put a cap of 3.8 inches on the tire size. That leaves 4 or 5 options for tires right?
