The Modfather
Need to change my name to n00b or something....
Ended up picking up the SCX10-II kit. Finally had a chance to get building after work last night. Step 1 - axles. Awesome - just like my old Scorpion, but smaller ring & pinion. EZPZ. Followed the directions to a "T". When finished, I noticed that there is a small bit of play in the pinion, and when it compresses, it seems to be binding up on the ring gear. Makes sense - it's slightly offset, so that is to be expected. Disassembled the rear axle to make sure I didn't jack up the ring gear & locker - nope - that was good. Did I miss anytihng? Was there a shim or something? Nope. Maybe the locker & ring gear "snap" into the bearing recesses. Nope. Looked thru all the parts - maybe I missed a shim or something that wasn't noted in the book. Nada.
I gave it a rest last night and kept my mind off of it all day today. Got home and decided to give em a tear-down and rebuild (RC Mulligan) - same problem. I'm kinda at wits end here. When the pinion is pulled out, there is no binding. Also, when I spin the axle one way, it's smooth. Spin it the other way and it draws the pinion up into the ring, and causes it to bind up.
Sooooo....is this a defective kit? Maybe the axle housing is funky? Maybe I am over (or under) tightening something? ORRRR - is this why I'm not allowed to have nice things?! :mrgreen:
This is not my video, but it is what I'm trying to avoid (15 sec): https://www.youtube.com/watch?v=vkZAQlRKh3E
