ILoveRCRockCrawlin
www.rcpcrawlers.comCould someone point me to where I might find the "Hustler" chassis like on the first page? Thanks
Or do you mean the buildup thread?
I am looking for info or even a pic of where to mount the lower 4link onto the axles. i am building my own frame and have looked at many pictures but have not been able to find a good pic of location. every pic that i have seen has a tire or some kind of mount, crossbrace, servo etc blocking the mount location. i have my axles and do not see a obvious place to mount the 4 link. any halp would be much appreciated.
Hey RockRevolver, did you ever finish up that number crunching? I'm currently doing the same thing. Here's what I've come up with so far:
clodbuster kit 190 towerhobbies
integy lathe 55t motors 37 towerhobbies
robinson 9tooth pinion 6 towerhobbies
tekin rebel2 esc 80 towerhobbies
the stick 199 thecrawlerstore
adjustable motormounts 30 thecrawlerstore
Hpi Bronco body 25 towerhobbies
total 567
txt 355 towerhobbies
integy lathe 55t motor 18 towerhobbies
robinson 9tooth pinion 3 towerhobbies
gd600 13 towerhobbies
total 469
I always thought the TXT-1 would be the more expensive option over the Clod...Is it because more stock parts are kept in the TXT build or something else????
total 567
total 469
How do I set up independant front and rear steering & throttle control besides having a 4 channel receiver, is there an esc that will work to do this? :?:
Clodbuster gearing info:
Pinion 32 pitch 13 tooth gear ratio 1:30.1 Speed, Stock 15mph / Run Time, about 8 minutes 2000mAH battery
Pinion gear ratio:
8T 48.89:1
9T 43.46:1
10T 39.11:1
11T 35.56:1
12T 32.59:1
13T 30.08:1
14T 27.94:1
15T 26.07:1
16T 24.44:1
Figured I'd post it since people ask about it alot!
thank you for your time if you read this and help me,
i'm on my second build and this one is a clod i have "stock axles". i see that a lot of people are runnin 8,9,10 tooth pinion gears, when i put a 10 tooth pinion on the motor and install it there is a gap inbetween the gears, how do you adjust it if there is no adjustments on the clod axles or are you sayin by the gearing info below that i need to go get a bigger internal gear, i guess i'm lost, please help if you can, my first build was with tlt axles and everthing was fine. thank you, jon
