How to build a Clodbuster Rock Crawler
Ok i will ask that there maybe you know why some people run two ESC's? Whats the point of that and how do you wire for that? Or should I ask that in the Electronics area?
Asking in the electronics or clod section would be best. Thanks.
can someone give me a list of everything i need that to build a mean crawler i would like a list of every part i need and where to get it
I am sure its been covered but I cant find it so a little help???
I bought a nn clod RTR and it has stock 540s in it.I want to change them to lathe motors but why the 55t and not the 65t or the 45t???Also since I have 9 tooth pinions and adjustable motor plates will changing the motors make a huge difference???And who has the lathe motors in stock???Thanks in advance for your replys!!!
The 55t motor gives you just about the right torque and wheels speed.
I think the 65t w/ 7 or 8 cells is a little better. But that's just my opinion.
And YES it will make a HUGE difference it your crawlers ability. Check the vendors section or for sale forum here on RCC for lathe motors.
Good luck and welcome the RCC
I read the link about making your own links, but I have a question about what size tap and screws to use when using the Traxxas T Maxx rod ends (part # TRX2742)? And would it be better to use the long, or short rod ends?
Thanks in advance.
That 6-32 rod size is correct to slide the threaded rod through the tube, just like the how-to describes.
If you want to thread the 6-32 rod into the tube, go to www.mcmaster.com and search for P/N 89965K44. I also wouldn't recommend cutting threaded rod for this method, but use mcmaster P/N 91375A153. This method takes longer than the one explained, but the links are lighter when completed. We've had no issues with any breakage to date so the choice is yours as to how to assemble your links.
The link to wire the EVX for a single battery is borked. There's a debate on another forum about doing just that ... where'd it go?
ok so i hate the look of those huge clod size wheels with 1/10th scale body how hard is it to convert to 2.2 wheels on clod axels and does it work worth a crap with that size tire on it
or will these work?
$25.00 - Pair
w/Foams Swamp Dawgs
Fits: T/E-Maxx™, Savage, Dominator
Height: 5.75"
Width: 3.0"
Diameter: 3.2"
these have bigger wheels but same height but not as wide as clod tires
could you do crawling without modifieing the heck out of a clod?
i mean leave it stock? suspension wise and drivetrain?
also what pitch are the gears standard? 32p?
thank you.
A stock clodbuster CANNOT crawl. Firstly, open differentials mean that as soon as one wheel loses traction, all power will go to that wheel and forward movement will stop. Also, the stock chassis and suspension mean that the truck is top-heavy (liable to roll over), and has almost no suspension travel (articulation).
Cheers 8-)
