So i discovered i am unable to return my 1080 for a warranty replacement for a couple of reasons, that are my own fault.
The warranty sticker is removed (i had it glued down originally an removed the sticker, for better bonding)
There is a few marks around the clips on the esc where the heatsink joins the body. This is when i had made a very gentle attempt to open it to try and get some de-case pictures.
Both my fault but obviously didn't contribute to the failure.
Since the capacitor popped and i ordered a replacement i figured that before soldering in the new one, the one old has to be removed to try and prevent further problems.
First attempt, to pull it out like a tooth.
Not possible to wiggle it side to side, due to how it sits in the ESC, so tried pulling it straight out and it fell apart easily, because it was already ruptured.
So with nothing to grab hold of and half a capacitor still on, it needed to be de-cased. Even with all the clips cut off from the case, the bonding from the conformal coating sticking the board to the case and heatsink etc, meant that it appears i have damaged the board in attempting to de=case it.
I'm not going to be put off as i think it was just purely bad luck so a replacement has been ordered and will stick my Hobbywing 1060 in with a Turnigy 5A BEC in the meantime.
