Do you have Running Mode set to Option 3 (FWD/REV)?I have this esc also and love it. Only problem I have is, when I try to go in reverse it doesn't do anything at first then moves. Is this programming?
A dim light bulb went off in my dark brain this morning. :lmao:3s / HH 13T CM @6.0v / spektrum 6230 servo. No hold on the incline and under full load the steering servo would glitch and cause tire movement.
Switched to 2S all the same settings and it holds / no servo glitch.
That's huge for HobbyWing. It's about time they get their name out there.Available at RPP, but shows “Out Of Stock” for now.
Hobbywing QUICRUN WP1080 Waterproof Rock Crawler Brushed ESC, (2-3S)
Try re-calibrating it to the transmitterWhen I turn on my crawler, I get a flashing ref light from my hobbywing, what is the problem?
Thanks
Thanks
eBay has them for $35 free shipping from a few vendors typically. It's about the cheapest way I've found to get them as much as I'd prefer to support a shop that supports the hobby more.
Running it in a comp crawler? Impressive! I'm glad to hear it did well. How did you do in the comp? I was almost at St Pete's that day if that's the comp you're referring to.So I finally ran this ESC in my 2.2 Shafty in a comp last weekend. It held it's own and then some. No issues with servo power set at 7.4v to a Hitec 7955 (being replaced with a 7950 shortly). No issues when running WOT forward and reverse to flip a turtle situation. Got stuck in a couple binds and the ESC stayed really cold. Ambient temp was about 55 and rainy. Overall I'm very happy with its performance and I'll continue to use it in this rig the rest of the season hopefully. Just wanted to check back in. Didn't see too many people trying to run a 2.2 comp truck with this ESC. Seemed like mostly scalers.
Pics for attention...
