Supershafty has been out of stock for some time now! :x
im still running the wraith transmission with metal gears,just put in the RRP one piece output shaft and broke it less than two battery's.at the cross pin on the rear driveshaft.i got an AX-10 trans i'll be puttting in when i get the longer output shafts.
i was running a traxxaxs venelion with MMP.drag brake at 80%,everything else on the stock setting.now im running the Tekin 3300kv 4 pole motor..need to know what tweaks you did to the MMP ESC to make it crawl better,mine still kinda coggs a little,not much.but trying to get it a little smoother.
thanks.sloyota
I never consider that to build a perfect durable strong and powerful wraith I was going to need 1500 dollars :ror: with that money you can even buy a 5th scale:lmao:
Hi, in order to keep it simple (as I'm ordering from the uk) I think I'll going to plump for the assembled complete bomb proof trans from supershafty:
Complete Bomb Proof Trans - Super Shafty
Can anyone confirm whether this will attach directly to the MIP drive shaft
https://www.ckrccrawlers.com/mip-spline-center-cvd-wraith-ridgecrest-p-3957.html
or whether I need other bits?
My wraith is currently stock (kit) with only steering link upgrade at the moment, I've decided to upgrade from the inside out, however, the motor will be my last upgrade (unless I kill it)
Thanks in advance
I just picked up a rc4wd centered diff.... and my stinkin' vp lockouts don't want to go on... this is my first metal axle, so maybe they need to be persuaded a bit, but I'm not positive... do you have any experience with this?
On the RC4WD housings I had in the past they forced you to use their lockouts by not fully machining the case. I'm not sure if that is the case or not.
I'm guessing you could tell if they looked that much different though. They may just take a tap with a rubber mallet or something.
I wanted to get a wraith as a step up from my custom micro crawler,
and this thread just scared me a good bit... :shock:
Yeah I can see what you're saying.
So bone stock with a 2S lipo and some aluminum c-hubs and knuckles and I should be ok....
I am thinking I may just go ahead and do this. Tower Hobbies has a $45 off $350+ order right now too....
I am also looking at getting a used one with upgrades already started.
is there a reason you listed two diffetent gear sets for the front and read axle in your links?
