Got it. So, I should be good since I've bolted everything up properly and used the right size Fast Eddy Bearings. Basically, I'm overthinking it. :mrgreen:
You got it :ror:
I have read the part where you talked about putting in the ax10 trans...
I already had the new metal gears and MIP drive shafts for the stock stuff
so my question is what else can i do to bullet proof what i already have with out buying new housing?
im running brushless tekin 13.5 w/3s
Thanks,
I have the stock top shaft. What brand and where would you recommend be buy it from.
I see you guys talking about replacing the top/input shaft. Is ti because the stock one breaks, or you want the larger one to accommodate the slipper from the Slash?
I've already upgraded to 32p gears but plan on upgrading the tranny to metal internal gears. Just not convinced yet that the top gear shaft is a problem.
The larger top shaft uses a thicker pin on the drive unit, when you have the rest of your drivetrain already beefed up this is an area to address. The Slash slipper gives MUCH more control over slip settings. The stock Axial unit is basically an on/off switch when running big power, you either have no slip or it slips under even "moderate" acceleration.
Well looks like im gonna need to save up about 600 dollars, HAHAHAHAH!!!!!!!!!!!![]()
They make a 48p version for the Wraith but I use the heavier 32p version for the Slash which requires a larger shaft from SuperShafty.com
Harley im building my buddy a Wraith right now... i got the RR 48p/80t slipper clutch, if i use a hardened steel 20t pin i should be good right? or is he gonna shred the top shaft... wish i had read this thread before i bought the 48p for it .. he is running a Tekin Rs esc with a Tekin 17.5 bL... also whats a good rule for setting the slipper tightness?.. hes a " pin it to win it" type driver!!:twisted:
You'll probably be fine. Just watch pinion wear over time.
I tightened mine down pretty good and then backed it off about 1/4 or 1/3 or a turn.
awesome man thanks i had the slipper set right.. i think i'll end up taking his slipper and up grade him to the Super Shafty once he gets a set of punisher shafts from rc4wd.. he still wants to run some kind of gear cover and i dont thats gonna work with the way his build is going.. i love his build cause he got some $$$ to throw at it!! side note.. i need to pull his trans out a again and every time i take it a part the top shaft always seems to have play in it but when its together there isnt any play any thoughts?
