re: Guido: Scale TTC Bronco 2012 NWSC Rebuild 49" IROKS(Paint and interior updates pg53)
So we go back a couple days first. I made a trackbar mount for the axle to get proper geometry but ran into a problem. The drag link and the trackbar ended up in the same spot when turning.
So I made this bracket that mounts to the steering arm. It moves the drag link out of the way.
Satisfied with that I started building the trackbar. A 1/4" diameter link was going to be too big so I had to figure out how to bring the strength with 3/16" tube. I grabbed some 3/16" stainless tube but the ID is only 1/8" so 3mm or 4-40 is the largest thread that would pass through.
I decided to use the Traxxas Maxx rod ends because of space and I like to use 6-32 with those rod ends. I decided to cut off a length and grind down the threads until it fit in the tube. Then I drilled a hole through the tube so I would have 2 holes to do a plug weld to hold the all-thread in place.
Between the all thread I cut a piece of 1/8" steel rod to fill up the tube. Then welded the all-thread in the other end.
I think this will be plenty strong for a trackbar and looks much more scale than the 1/4" tube. I think I'll do this with the steering links as well to look more scale.
I beefed up the "steering box" by drilling out a piece of 7/16" stainless tube with an 11/32" drill bit. This allowed me to slide the brass bearing supports into the stainless tube. Now the steering will be beef and I won't have to worry about the brass supporting the bearings under high stress.
The front coil spring mounts moved forward by about .75".
Today started with the trackbar mount for the frame.
All boxed in and speed holes drilled.
Welded to the frame and the coil spring mount for support. I had to tie it into the steering box but I think it will be plenty strong.
I decided not to grind off the welds. I kinda like them.
Sorry for the blurry pics, I gotta work on the camera settings. :x
