Thanks man. 8) The last steering box design worked fantastic. Even when the front driveshaft was broken and I was in 2wd on the finals course, I was able to steer perfectly.The steering box on that thing is outstanding!!!! How did it fair in the last Nat? I was thinking of making a similar set up for a rig that weighs around 13 lbs, do you think it will hold up well under the weight? Thanks for any help you may give...
I was afraid with the new design that there might be some slop because the link from the servo does not connect to the same point as the drag link. But the test run at the last Scale comp went really well and the steering worked great.
You could likely get away with a 16 gage steel (.060") pitman arm, I believe that's what War Pig's is made from. But I went with 1/8" steel for the extra measure of strength for a heavy rig and the thicker material has a more scale appearence imo.
You can watch the steering work in this video from 2008.
http://www.youtube.com/watch?v=_448HAyL-uQ
