racerx
Parma sells them.
where did you get the engine?
Parma sells them.
Almost forgot to show you the Powertank. Norm was kind enough (a bit of persuation from Juan helped too :ror to include me in his last run of tanks. While they are absolutely amazing in their scalism the tank was just too tall. I took a hacksaw and cut mine down. The bottom cap wouldn't fit on because it is slightly smaller diameter than the tank so I put the cap in front of my heat lamp until it was nice and hot. Then I slid it on as the plastic was soft enough to expand an fit over the tank.
I like the size better and it will be easier to fit now. Thanks for a great product Norm. "thumbsup"
Thanks John. Once I finish the body panel mounts I'll get some pics up. I think it's got a neat look to it. Yup, it's all welded together, should be nice and stout. You should build another tuber, I'd love to see what you come up with.Wow, that front end is nice! Is the front welded together?
This rig really makes me want to build another tuber one day, just such awesome work!
No worries Norm, it was an easy mod. Juan and I talked about it the day it showed up, I just had to build up the courage to cut such beautiful work apart. All it needs now is some touch up paint on the bottom cap.My god man. all you had to do was ask. Tim is having the same issue and i just sent him 2 tanks to cut down and they will be off to juan. maybe tim wont need the other one.
No worries for you Norm. That buggy of yours is sick and the work you are doing on it is top notch. "thumbsup" It is I that am worried, I just hope I can get all my ideas to work in time. :ror:I see you got the parma engine in there. You need to stop now. I cant compete with you and Tim anymore ever. and Zack just keeps building and building. Your all not fair.
Thanks Prime, I appreciate it. 8)I just reread this thread for the third or fourth time since it was started and I am still blown away. Great work, he gets better and better with each rebuild.
I have a question though about a past set up you had on him. I remember reading that you were at one point running a pair of 1500 2/3A backs with a 10t puller. I was just wondering what kind of run times you were getting in this configuration? And other than them not being lipos, were you happy with that setup? I ask because I am building a truggy that is going to be rather heavy and I am planning on running a pair of 2/3a packs and either a 7t or 10t puller through a 2sp emaxx tranny. I also plan on using your 7.2 to 14.2 switch mod as well (thanks for the write up on that btw).
Thanks again for sharing the awesome rig and tips along the way.
Chris told me he cut it in half and junked it, starting from scratch. :shock:
Well let's hope she has the attitude of a bad beeotch in heat.
I won it in a raffle, it will rest on my shelf forever!!
