OSRC
Most of my old crawler club has migrated to semis and construction kits. Cool stuff, but I've never taken the plunge myself. After going to a local show and seeing everything in action, decided I needed to add one to my collection. Most of my crawlers are good to go, all winter maintenance is done, I need a project!
A Tamiya kit would have been my preference, but the prices have skyrocketed over the past few months, and there's no way I could swing one of those. Using some X-mas money, bribing the wife with flowers and the promise of some home renovation, and the remaining funds in my PP account, I cobbled together enough to pick up a Hercules Hobby Actros kit.
Had to have a theme...and it's about time I merged some of my interests. Prime has been done several times, but I don't know that anyone has attempted Galvatron from TF4 AOE....I think he's badass! Too bad Michael Bay seems to have totally abandoned him between movies, but that's another thread.
I know that he's a Freightliner Argosy and I've got an Actros here so it's not quite going to be the same, but I thought it was a close as I was going to get. I'm going to use the color scheme and add similar lighting...should look pretty cool when done.
Enough blather, let's get some pics. Going way, way out of my comfort zone on this one....this is as much a model as it is an RC kit. I've built gobs of kits, but never anything this involved. Staggering number of parts. Too bad you can't see them since the chrome is messing with the damn camera.
I did pick up some cheap alloy wheels while I was at it. Galvatron has black wheels, but ain't nobody got time for that. He's getting an upgrade whether he likes it or not.
First thing I do with any kit is fondle the tires.... Tires feel pretty soft, but have the hardest foams I've ever felt. Maybe this is normal in the semi world, I have no idea but these suckers have NO give.
Oh boy....I knew I wasn't getting Tamiya quality, but the first plastic part I screwed into cracked. That's not good! (Crack is on the right screw hole) - I replaced the tapping screws with machine screws and used locknuts instead. I've been heavily greasing the screws before threading them into the plastic and so far it's been going better.
Hopping around a bit, step one is chassis rails. Chassis rails are aluminum channel instead of steel like Tamiya. They were a little warped out of the box, I gently bent them straight again. With all the cross members installed, should be plenty solid.
Directions are somewhat iffy. Not a beginners kit for sure. Occasionally, there's a step where there are no part numbers, and I'm left searching though all the parts trees for matching parts. And not all of the parts trees are labeled either. Note on the right - no parts numbers!
Found them!! After a while, I clued in that the parts not labeled are specific to the rear 4 wheel assembly. Assuming they just added a few additions from the previous 2 wheel kit.
Rear cross members are multiple pieces, took a little bit of hunting to track them down.
Here's where Hercules quality is nowhere in the same league as Tamiya. The servo holders were just held together with standard head phillips screws, even where they are slotted to allow for servo size adjustments. I know better, and added some washers under the screw heads so the plastic doesn't get warped.
Same with the servos...mounting servos with standard head screws is a no-no. Found some large flat head servo screws in my stash and mounted them both. Much more solid. Std. Futaba servo for shift duties and a Hitec 645 for steering. Should do I would think.
Took nearly 3 hours to get to this point... it's coming together slowly!
Rear leaf springs... pretty cool setup. Had a nice diagram, but again, no parts numbers. Had to do some hunting...
And mounted up, they mount inversely.
Steering block steering is the same setup as Tamiya and very similar to the Hi-lift kits. Had a ton of play, I added some 5mm washers to get the slop out. Kit does have full bearings which is nice.
..... and I'm out of threadlock, so it's off to the hardware store! "thumbsup"
