SkaldidDog
2013 2.2P Nat. Champion
Placed."thumbsup"
Thanks William!
J
Thanks William!
J
Will...I'm curious what effect running these gears along with a stock small 2nd gear and the usual Robinson steel pinions might have? Will these hardened gears get along with other gears that may not be of the same type? The reason I ask is I know with the Robinson hardened steel spur you have to run a hardened pinion or you'll end up with a pile of metal shavings that use to be a pinion.
So will these be available forever more or is this a limited time run? It would be nice to know that we have an ongoing source for replacement gears "thumbsup"
Great job William!
Assuming they still sell, I will still produce.
If these roll out like we all hope, small 2nd and 3rds to follow in due time.
Any plans to do the little gears too?
