Today was a good day so I made some more progress. After getting the bends done up I had this.
It fit the old plywood set-up pretty well...
... and the body will cover it like this.
So it was time to leave the forest and step into the modern world, so to speak. I got the new chassis all drilled and filed, and with a little fitting...
I present my new RC12e-volved.
While I was setting up the alum', I bumped the wheelbase 5mm and spread the front track 10mm, for a better fit to the body. Also changed the steering set-up, got rid of the old belcrank/saver, simplified the whole front end and shaved some weight.
Then I painted the bottom half... Wahwahwah.... I guess maybe I should've let the purple cure a couple more days, 'cause the white seeped up under the edge in a couple places and it looks like little white grass is growing on top of the white half. aaaaaaargh!! So it goes, I'll fix it somehow.
Still lots to do, and I ran out of day, so I only got to test drive the new chassis in the house. So far so good.... Now the real fun starts.
