Well, it's taken a few days, the weather's been from rain to 100+ deg. heat-index, but I got the camera set-up mounted into the 'Jockey.
I pulled out the seats and made an aluminum "Z" bracket that uses the seat screw to hold it in.
Then I made an "L" for the transmitter. The cam's record start/stop button is on top, so I loosely taped a stack of small wood blocks to the top that rise to within 1mm or so of the lexan roof.
Now I can just press on the roof to start/stop recording. I had trouble with the micro-SD card, and after the first few test vid's, I couldn't decode and view anything it recorded. But after re-formatting it, it seems to work .... but I'm still only recording one or two videos at a time.
Here's a "selfie", so you'll know where you'll be sitting.
Now, buckle in, and grab a handful of steering wheel .... (sorry, I still don't know for sure which link to use ... bear with me)
http://vid1315.photobucket.com/albums/t599/dr_frankenstyle/Drivers Seat 013_zpse02fjznm.mp4
or
Anyway, that's with the 60t spur. I wasn't really happy with the wheelies, so I put in the 54t, and tried again. It all happens pretty fast, but if you pause it just right you can catch the hood pointing up for the first few feet.
OK , here we go again ......
http://vid1315.photobucket.com/albums/t599/dr_frankenstyle/Drivers Seat 014_zpsjaucbtux.mp4
or
HEY, why didn't you hit the BRAKES !?
Actually, the pinion came loose right out of the hole after that last turn-around.
I don't think you can hear it, but a truck topped the hill behind the 'Jockey at the same time as the pinion came loose. So I tried to steer to the "safe-zone" by my feet, but with the loose gear there were no brakes (those disc's are WORTHLESS
) and I almost hit me, I mean, YOU almost hit me
Anyway .... hope you liked riding into the ditch. 8)
....and at least grass is easy on lexan, so no harm done.
