Doomps AR44 Capra
Doomp
Venice
Firstly yes i know the gearing is all out of whack with this combo... However it kinda works and crawls.... good?
Wheel base: 11 3/8
Width: 9 1/8
weight: IDK
Parts list:
Leftover capra cage/skid/body panels
Used auction capra tranmission modded to fit 10T pinion
Yeah racing 95MM lower links F/R, element rod ends, vanquish brass balls
Yeah racing 80MM upper links F/R, element rod ends, vanquish brass balls
Yeah racing desert lizard 100MM shocks soft springs, full droop
AR44 3 Pc axles
SSD c-hubs
SSD pro knuckles
SSD brass weights F/R
SSD rear lockouts
SSD aluminum link mounts F/R
SSD aluminum diff covers F/R
axial stepped hexes
SSD front overdrive R&P 8/27
SSD standard R&P 8/30 rear
vanquish 6 bolt lockers F/R
Element steering links and rod ends (modded), vanquish brass balls
UCFab axle servo mount
SSD 25T servo horn
Electronics:
hobbywing 1080
HH crawlmaster sport 16T
reefs 422hd
CC 10 amp bec
spektrum sr315 rx
spektrum sx107
lightbar/headlights
Wheels:
SSD double time beadlocks
SSD wheel hubs with brake rotor F/R
proline TrXus tires 4.50"
stock foams
Paint:
tamiya PS-23 gun metal
tamiya PS-12 silver
I managed to get out to cap sante here in the PNW acouple of days ago and ran four 1300mah 3S packs through this little abomination and im pretty happy with the overall performance of the truck.
vertical climb is exceptional
side hilling is great
plenty of wheel speed (too much)
the crawlmaster sport drag brake is meh, could have been my settings or possibly the high FDR.
Now that all that boring parts list is out of the way on to the pictures,
Drumroll pleassseeeee
